Can I "Zone" heat?
bankcardrep1
Member Posts: 7
I have this new boiler which is doing great. I am just wondering if I can turn off some radiators?
The north side of our house is heated by wood stove in basement. I was thinking of turning off the two radiators in those two bedrooms. They stay 70+/- without radiators.
If I turned them off would the others heat sooner?
Advantages or Disadvantages?
I asked my installers, a father and son team at different times and got different answers. One said NO dont turn them off, the steam needs somewhere to go. The other said "leave them open a little".
Confused.
Confused.
no zones
Take this with a grain of salt as I'm no pro, but this is what I've learned from Dan's books.
If your installer was worth his salt he measured the EDR of your radiators and sized accordingly. Now you're saying you want to disable a couple of them, making your boiler oversized. This may work ok but will be less efficient (perhaps a lot so).
I'm not sure what they want to leave open "a little." If it is the vent then that is probably ok. You might be able to use a temperature vent to close it too. If he was talking about the radiator valve then no, it needs to be either open or closed.There was an error rendering this rich post.
That's
what I'd do.All Steamed Up, Inc.
Consulting0 -
vacuum breakers?
Whats the ideal location for the vacuum breakers in this situation?There was an error rendering this rich post.
TRVs
To save on fuel I shut down parts of my house during the winter by using TRVs at their lowest setting. These keep just enough heat (42 degrees) in these rooms to stop the pipes in the wall from freezing. If you wanted to heat the areas with steam you'd just turn the settings on the TRVs to what ever you wanted. TRVS or just shutting off the radiators is much less expensive/ hassle than using zone valves I would think. Just a thought.
- Rod
Edit: With the Danfoss RA2000 1PS, a vacuum breaker is built into each TRV valve. Be sure you get the 1 PS (for one pipe steam) as this signifies it has the vacuum breaker.0 -
vacume breaker
don;t you need a vacume breaker on every Trv. thats what we do.0 -
vacuum
- just realised my bad spelling
TRV Brands
What thermostatic radiator vent valve is best for 1-pipe vent control? I have used Macon vent valves in the past. Is there an established test for T-static vent valves? Sometimes there are differences in tehnology that make a difference for certain applications.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 849 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
