radiator tapping question
Timco
Member Posts: 3,040
I am putting a larger rad in my basement b-room, and it has tappings from bottom to top diagonally. Question is, should supply be top or bottom tap? I am guessing bottom because heat rises and would heat rad better that way? 2-pipe. I have always piped across bottom but would like to not have to change the tappings on this.
Tim
Tim
Just a guy running some pipes.
I wouldn`t bother to change-it Tim,
The rad is going in the basement anyway(lowest point of system),,, with the proper circ to handle the flow through-it,,, your efforts to change the tappings will be a negligible gain at best. ;-)
PS- Just remember to add a drain-faucet if you ever need to,,,,,,,,,0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
