Steam Boiler piping
Jim Pompetti
Member Posts: 552
Low-pressure steam February 2010 Page 36 . What do you think
Sorry
Fuel Oil News0 -
unneeded technology
If insulated and installed properly by SKILLED tradespeople steam is quiet and the insulation works wonders. I am amazed some one is spending time researching steam though. Thanks for sharing the article. If they took the money and designed a better boiler I would be excited. Also running 2 psi is his first mistake.Cost is what you spend , value is what you get.
cell # 413-841-6726
Plastic Steam
Thanks Jim- Interesting article. I'm not sure what to make of it. I'm all for innovation in residential steam though can you even imagine what sort of near boiler piping configurations we would see on the Wall if the "Cut & Paste" guys got into steam?!
Polysulfone is probably the only plastic you could use for steam though I really wonder about its longevity as its physical properties do degrade at high temperature (175 C) . somewhat over time. Maybe at 212-215C this isn't a problem? (If anyone is interested here is the design book on Polysulfone http://www.solvayadvancedpolymers.com/static/wma/pdf/4/0/6/UDG2004.pdf)
I don't think it would have anywhere near the longevity of black iron piping and I would think it would need a lot of extra support to prevent sagging. It sounds like there would be initial benefits (Cut& Paste) however things are much different from the lab to real life. I think I'd be more interested in the controls and accessories they come up with.
Maybe if we can get the Polysulphone guys together with the Vaporad people http://www.fraccaro.it/en/vaporad_termostrisce_vapore.asp?pa=ho
they could come up with something practical. I agree with Charlie, put the effort into more efficient boilers and better controls
- Rod0 -
Looks interesting to me
this could make new steam systems economically competitive.All Steamed Up, Inc.
Consulting0
