wet returns
Luv'nsteam
Member Posts: 278
I am replacing all of the wet returns. Use black or galvanized pipe? Advantage of one over the other?
Thank you,
Mike
Thank you,
Mike
Pipe
I think Black Pipe is the norm. I seem to recall that the heat affects the galvanized stuff...
Also less expensive
Scott0
