700 auto air vent
joebear
joebear Member Posts: 2
when using 700 auto air vents,does the cap need to be loose to vent air or can air be vented with cap closed?
  • 700 auto air vent
    I must be tired,,,,, who makes that?
  • joebear
    700 auto air vent
    amtrol
  • Big Ed_4
    Big Ed_4 Member Posts: 3,348
    Depends
    The older models with the schrader valve , the cap needs to push down on the pin just a little vent out the air .. The schrader valve was a secondary valve ... Seems like they added the schrader as a safety valve ...Cap fully closed , open or missing the vent is closed ....
    i cut one apart years ago when this question came up ...
    In the newer models the schrader seem to be deleted ...
    Second note.... From inside their paper work , you should set the cap just slightly loose . They don't want a rush of air, water and dirt to foul the valve seats ...
