crazy question/crazy customer / need an answer
Coany
Member Posts: 90
we put an attic a/c system in a one story cape.
no rooms on second floor, big open attic, well vented, cold up there
The customer is a germ-o-phobe, mold-o-phope,draft-o-phobe.
in the off season the customer covers up all the registers with sheet plastic,
taped at the edges. She thinks the humidity from her super humidifier will migrate up there and condenses leaving puddles in the ductwork and encouraging mold growth.
She is getting a few teaspoons of condensation in the sheet plastic
at a few different registers. We go over there and uncover everything, run the fan for a half hour and she's fine again.
she wants a more permanent solution... any ideas?
she runs two clean air machines and a steam humidifier which she keeps at 33%.
oh and she is some kind of a scientist.
she has thrown service people out of her house for coughing sneezing or farting
so everybody just walks in and coughs to get out of finding a fix for her weird problem. It actually says on her service screen"NO COUGHING BURPING,SNEEZING OR FARTING ALLOWED IN THIS CUSTOMERS HOUSE"
Where to start
Sell her UV lights for in the blower/coil area
plastic,
encouraging mold growth. Yes it can migrate into the ductwork and condense on the colder surfaces, sometimes severely if the humidity is too high. Thats partially why the humidifier companies want you to adjust your humidity settings based on the OA temp. Aprilaire gives you a OA sensor for there humidistats specifically for this. Possibly adapt this method to her steam humidifier
run the fan for a half hour and she's fine again. Make sure all boots, plastic or metal are insulated well
Disconnect the ducts and cap off in the fall and reconnect in the spring
at 33%.
farting
Good luck, people with phobias don't bend very much. Maybe start coughing or sneezing0 -
thanks
she already has a UV light, which she drives us nuts about because there is no indicator light on it to show its "ON".
Its pretty hard for any homeowner to tell if those things are working.
we already re-wrapped all the boxes and made sure the fiberglass was up tight to the boxes
I actually think she might like the idea of dis-connecting the runs, but she will not like the idea of leaving them open in the attic all winter, we would have to plug the box and the
run.
when the temperature drops she should adjust her 33% setting down some.
Thank you for the help.There was an error rendering this rich post.
Challenging customer
thanks
is no indicator light on it to show its "ON". You can buy LED lights from ABCO or Radio Shack for different voltages and mount one directly or remotely from the Light or mount a video cam inside the plenum and connect it to her computer. All of this would be charged appropriately of course
tight to the boxes
winter, we would have to plug the box and the. Thats easy to do. going back there repeatedly is not
run.
Again the aprilaire Humidistat will adjust automatically. Having her adjust manually by OA temp is just another phone call to you.
Thank you for the help.0 -
Use foam board instead of plastic
Maybe if one inch foam board is used to cover the ducts there will be less of a chance for condensation. Plus if there is any she cant see it, unlike the plastic.
Dan0 -
another good idea
thanksThere was an error rendering this rich post.
crazy answer
Sell her what she needs! In the attic unit install the steam humidifier with an outdoor temp sensor to auto adjust the humidity level,also install a Trane or Carrier super Clean Effects air cleaner and install the UV light in the attic unit. Put the fan in the " on " position for the cleanest air possible. IF she's proud to be a card carrying germaphobe then she will go for it.As far as the coughing ,sneezing,farting,etc,put on a body condom and a respirator,but charge her up the dupa on your pricing. Good luck0 -
Heat Recovery Ventilator?
Would a heat recovery ventilator be a solution? It would be running continuously and work in conjunction with her air filter and UV light.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 109 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 965 Plumbing
- 385 Solar
- 15.3K Strictly Steam
