LWCO: Float vs Sensor
shoudabeenaplumba
Member Posts: 74
A friend of mine was replacing a boiler today. It was a 2 year old Steam Burnham I helped him install. He said the float got stuck and no one checked it, so it cooked.
I always thought low water cut outs were things that helped you sleep at night, not keep you up. Is one style better than the other?
LWCO
Did he test it once a week?0 -
lwco, which is best
As Rod said, was it blown down weekly. I believe in probe type as you dont' have to flush them down and I've seen so many failed boilers due to lack of maintenance of the lwco by both the owner and the service company. However, you should clean the probe annually when the boiler maintenance is done. It can foul as well and give a false signal.0 -
LWCO
Either one must have proper service.
The probe type can act up and keep the boiler on when it shouldn't be.
I like the float type but seldom install them on new installs because of the cost.
The advantage of the float type is the burner will stay on while it is adding water.(steam)
If your boiler is on the small side and it is cold out the ten minutes that it is off every hour while it is adding water may be enough to not heat the house up to setpoint.0 -
I'm sure he didn't check it
How could a float keep a boiler on longer than is should? I thought it was just a NC relay that broke power to the burner.0 -
Steam Leaks
Their must be a few leaks in the system as well .... When Loosing steam the system must make up with fresh water … Water after turning to steam would leave behind minerals or what is call solids ... This would gum up the workings of a mechanical low water cut off .. Steam leaks cost you money , burns more fuel and corrodes the system ..
Steam is a hand on system , it needs maintenance and checked regularly ....There was an error rendering this rich post.
Muck
Solids collect the macanical low water cut off and prevents the float from falling .. Should be flushed when burner running to make sure burner turns off ..
Sometimes the switch would fail, could be improperly wired , or jumped out for the wrong reason ..There was an error rendering this rich post.
More than a few times
I've repalced many a steamer and got the " deer in the headlights " look from the customer when were done .......... after explaining the float lwco needs to be flushed once a week . Alot of them come right out and admit they never did it before .
Now we install mainly probe style . And 2 is better than one . Cheap insurance in my opinion .0
- 87K THE MAIN WALL
- 112 Chimneys & Flues
- 106 Geothermal
- 980 Plumbing
- 388 Solar
