Radiator coinnection leaks
Sandy255
I have replaced an old (c. 1920) coal/oil boiler with a new high efficiency gas boiler. Works beautifully but I now have small leaks from several column radiators where they connect to the valves. Tightening the nut does not completely solve the problem.
One radiator has been an historic problem: when I first disconnected the radiator about twenty years ago I noticed that one of the "dead guys" had sealed the fitting under the nut with some sort of packing. I used new packing and (rarely) had a problem - until now. I've tried graphite valve packing and various plumber's sealing compounds - even waterproof silicone. The water still runs out. Suggestions please.
Leaks
Is this a steam or a hot water system? It might help it you could post a picture of the leaking connection.
- Rod0 -
Union Connection
Clean the old union contact surface with steal wool , then dab just a little plumbers grease on the contact surface area to make up and imperfectionTry not to get any grease into the system ....There was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 50 Biomass
- 75 Chimneys & Flues
- 93 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 855 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
