man hrs/ to install 3/4 PEX with an uncoiler?
robert borders
Member Posts: 48
got a factor to multiply times the feet of PEX to install that reflects labor hours, or in other words how many feet per hour or per half day or per day using an uncoiler for 3/4 PEX?? have a job with about 1000 ft of it to install
thank you
RB
Bobs heating
319-795-0822
<a href="mailto:rlborders@iowatelecom.net">rlborders@iowatelecom.net</a>
thank you
RB
Bobs heating
319-795-0822
3/4 PEX
Too many variables here, Robert. You didn't mention the installation technique or for what purpose. Inside or out? Heat PEX or AQUAPEX? I assume you may be doing snow melt with this? Usually very quick to get the PEX in but how is it secured, etc? More info needed0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 3.3K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 87 Job Opportunities
- 27 Recall Announcements
