check valves
STEAM DOCTOR
Member Posts: 2,648
what is the purpose of check valves on hw zones on steam boilers
check valves
They exist to keep the zone from gravity feeding and to help keep the water in the zone0 -
thanks
does it matter if the check valves are above or below the water line and if they are before or after the purge valves0 -
check valves
if the entire loop is below the water level are the check valves necessary? also is it necessary to purge a loop that's below water level? if yes are two purge valves necessary or can the loop have a single purge valve and the boiler it self will function as the discharge valve? thanks0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
