check valves
what is the purpose of check valves on hw zones on steam boilers
  • Al Letellier_21
    Al Letellier_21 Member Posts: 400
    check valves
    They exist to keep the zone from gravity feeding and to help keep the water in the zone
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,586
    thanks
    does it matter if the check valves are above or below the water line and if they are before or after the purge valves
  • STEAM DOCTOR
    check valves
    if the entire loop is below the water level are the check  valves necessary? also is it necessary to purge a loop that's below water level? if yes are two purge valves necessary or can the loop have a single purge valve and the boiler it self will function as the discharge valve? thanks
