Wet Steam
TeaKettle
Member Posts: 1
I suspect their may be some "wet" (i.e. not wholly evaporated water) escaping from our radiator. There's condensation on the ceiling above it and on the window* in two rooms (both next to each other). There's a "moldy smell" to boot.
I'm wondering if this is a problem with our pipes alone, or building-wide? Maybe with the boiler's ability to make dry steam? I'd love to hear anyone's opinion, including any possible solutions.
Thanks in advance
*Which is directly above the radiator.
Thanks in advance
steam leak?
can you see any vapor escaping from the vent, or the shut off valve. it's not good for the system to run with any leaks; and neither is it good for the building to have an excess of humidity.
both leaks are relatively easy to repair, either by changing the air vent, or tightening the packing nut.--nbc0 -
1 pipe or 2?
you don't specify your system type? it is a bit strange but if you don't see it or feel it escaping from the rad or surrounding pipe, it's probably not your heating system or at least a part of it you have ready access to.1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
