Weil Mclein Oil Fired Boiler
joseph_3
Member Posts: 3
I have a Weil Mclein oil fired boiler that we just drained out and then filled back up.
Went to fire off the boiler and it ran for about 2 minutes and then shut off.
This keeps on happening. Could someone tell me what the problem might be?
thanks in advance.
thanks in advance.
oil fired shutting down
Too many unknowns and too little information to be of much help. You didn't mention if a steamer or hot water. If hot water, maybe a low water cut off seeing air in the piping. You need to use a meter and determine what is shutting down the boiler. Where is the electrical path being interrupted? What control may be doing it's thing without you realizing it?
Take a little time, get a multi-meter and be patient. You will find the problem.0
- 120 Geothermal
