instructional aids
lapstrakelenny
Member Posts: 2
Hi. My name is Len. I'm a gas instructor in Manitoba, Canada. Our program involves instruction in the Fundamentals of gas fitting and servicing. One of the elements of instruction is working with gas fired boilers. I use two videos published by Weil Mclain of their "HEAT" series of instructional videos, one on Steam boilers and one on Hydronic boilers. These are fairly good in many respects. Keeping in mind that this is a general learning format, I'm looking to improve the selection of training videos on hand to include larger input boilers and/or more in-depth service and maintenance oriented material such as annual servicing of steel boilers, flushing, maintaining water level, etc. This material may be offered to students online through our library access which is a protected learning platform. Primarily, I would be delivering this material in class to residential and small commercial fitters and later to General Gas Fitters dealing with appliances of unlimited inputs.
Does anyone here at this wall have any direction they could give me in accessing appropriate materials. I'm not that concerned about jurisdictional differences (US/Canada) in terms of code and environmental issues as we deal with that in class.
Thanks,
Len Osland
Thanks,
Len Osland
Reply
NFPA 54 Gas code0
