Toledo die heads
Charlie from wmass
Member Posts: 4,422
I have a Toledo #2 gear reduction head. Any ideas where I can get new or good used ides for it? I am set for 2 1/2" just need 3" and 4" I will skip 3 1/2" as I hardly ever come across that anymore, thank goodness. Thanks guys.
cell # 413-841-6726
cell # 413-841-6726
Toledo die heads
Charlie, I have the same threader, don`t enjoy using-it but does come-in handy!
I looked on eBay and some guys do have the dies for sale,, not very cheap, but they are around.
Check-it out,,,,, :-)0 -
A lot better than armstrong dies
Several years ago we had an over zealous clean out of the shop and out went the dies. I am glad the head and the collars were saved. it was a full year before I realized they had been thrown in the scrap pile. I wonder why that guy was fired? Any way I am tired of welding the larger pipe and I was looking for a good source for the dies. I should probably just go get a rigid but I am kind of attached to the old toledo head. I have a post card from the building of the Empire State building and they are using the same head in the photo. I like the idea a "Dead Man" or two used the same diesCost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
