Burner code
George_22
Member Posts: 4
in Oil Heating
What is the distance from a homeowners electrical service to a oil boiler/furnance?
Thanks!
Thanks!
Depends
Depends on what state you live in. Here in Mass it is 5' from the closest part of the tank to the point of combustion.0 -
Burner code
Live in Mass, I do know that we need to be 5' from the burner to a oil tank. I am wondering on the distance from your house service panel to the boiler/furnance.0 -
oil tank clearance
Varies from state to state but here in Maine, the electricall code calls for a 30" box around the electrical panel for access. That 30" can be centered on the panel or from either side, which means the edge of the tank can be right up to the edge of the panel. Just attended a class by State Inspector for Home inspectors and that is how the Maine guys look at it.
AS long as there is a 30" space for a man to stand in front of the panel without having to reach to his side, you are OK0 -
Clearances
OOPS>>>>misread the thread....but we still can place a boiler/furnace close up to a panel as long as access is OK to the panel. Often time a wall hung condensing boiler will share a closet with a panel.....0 -
Three Feet
The electrical code calls for that to all other systems for access. unless it is more than a certain number of feet above the panel. ( don't ask)Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
