replacing old oil clunker boiler
ddenny
Member Posts: 75
what do you guys have for a favorite boiler replacement for an old clunker. If someone wants to replace an old oil fired boiler in a non emergency situation,; what would you choose. and how much less oil would you expect to use. my guess would be a little less than 10% or at best maybe 15%.
Ocasionally I'll do a boiler replacement and I've always gone with a buderus with a riello burner. what are your favorites. thankyou
dennis
dennis
steam or hot-water?
i'm not sure if it makes a differnce, but can you specify whether you need it for steam or hot-water system?
also specify if you expect it have a tankless coil or indirect set up for DHW?
lastly, you may want to mention how large a boiler you need (based on EDR of connected radiation) ..
i think all of these things may play into providing a good recommendation.1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
replacing old clunker boiler
the boiler replacement I have in mind is forced hot water, no tankless coil, indirect water heater. a small 3 section boiler. dennis0 -
Buderus Riello
Great choice.0 -
BNL
BNL did a study on the savings potential in replacing oil boilers.
http://www.nora-oilheat.org/site20/uploads/FullReportBrookhavenEfficiencyTest.pdf0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
