Water Level
Sly
Member Posts: 29
Hello,
I have a steam system. Every time i drain the water to the correct level on the water gauge, it will go to the very top of the gauge in a few days. Why do this happen? Do you think my automatic feed is faulty?
Thanks
Sil
Thanks
Sil
Dirty Mains
It might take a long time for the condensate to return to the boiler because the mains have mineral build-up or sediment blocking the way. By the time the water comes back, the boiler has already replenished itself and the water level goes up.
Also, your main vents may not be working, causing a vacuum. Check them and make sure they are both letting air out and back in when the system turns off and cools.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
another possibilty.....
is that if the boiler has a tankless coil for your hot water ... it may have a pinhole size leak in it....kpc0
- 117 Geothermal
