HOW NOT TO PIPE A BOILER
crash2009
Member Posts: 1,478
After doing some research on one pipe steam it appears that this boiler is a good example of how NOT to install. It seems to break ALL the near boiler piping rules. Of greatest concern to me is the lack of an equalizer and a Hartford loop. I have included a sketch of how the main and return lines run. I am planning to correct the near boiler piping in the spring or sooner if necessary. Currently the 1 system riser goes to a T, I was wondering if we should break up that T, and have 2 system risers going 2 directions resulting in 2 separate loops with a common connection to the bottom of the Hartford? Also, What do you think the steam is doing inside the current configuration?
Any answers on this one?
Any answers on this one?0 -
Yes, i'd break up the tee.
and vent the two ends heavily.gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.0
