Flexible Oil Lines? Do you use them?
cwilliams2000
Member Posts: 140
I have a boiler with a swing door and would like to have a flexible line installed for the last few feet to make opening the door easier. Do you use these, and if so do they typically meet code, and would you share a pic of your install of them? Thank you
Nice pics!
Nice pics,Ron!To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
yes
Only way to make a door open. To many service calls with boilers that can't really be opened without making a mess with fuel.0 -
My Personal Favorite
is a hard piped return in front of the door.0 -
ARRGHH
I still cannot figure out why the return pipe is there. (If we are talking about the same boiler.)0 -
There's More Than One
brand with the return there.0 -
9 times out of 10
I'm working on a beckett burner, and when I am I end up pulling the fuel pump to check the pump screen, so the fuel line is disconnected anyway. Very few underground tanks are still in service around me, and even fewer of those have two-pipe systems. The only braided fuel lines I see are Tigerloops, and most of those are commercial burners.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 392 Solar
- 55 Water Quality
- 46 Industry Classes
