gun to my head
blackpipe
Member Posts: 2
steam comes up the pipe and stops below the floor on the third floor ,so the radiators on the third do not get hot the pipes in the floor are steaming hot but the pipe leading up from the third to the fourth including the radiators are cold
need more info
pressure setting?
EDR load?
boiler make and specific model?
boiler rating in BTU or sq ft of steam if stamped?
1-pipe 2-pipe?
TRVs installed?
type of rads? baseboard, free standing, convectors?
did it ever work?
type of vents if any on rads?
is the system balanced?
also see this radiator checklist here: http://www.heatinghelp.com/forum-thread/129206/Radiator-not-getting-any-heat#p11850511-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
