radiant panels and pex al pex
clammy
clammy Member Posts: 3,227
Does anyone have a part # for a adapter from uponor 1/2 pex al pex to the standard buderus panel rad divertor valve (has r 2o threads ) the standard QS mlc fitting does not properly seal teh o ring being the divertor valve has a larger bore diameter thansk for any help clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
  • CMadatMe
    CMadatMe Member Posts: 3,086
    Fitting Part Number
    Wirsbo part # is D4120500 1/2" MCL Compression Fitting Assembly R20 Thread or D4020500 1/2" MCL Press Fitting Assembly R20 Thread
    alheim
