Radiant Heat & Humidity?
Kungur
Kungur Member Posts: 49
As I consider a retro to radiant floor heat I was wondering how those of you who have it add humidity to your house?
  • Why?
    Radiant heat does not make the air any dryer.
    Many farced air heating contractors will try to scare homeowners with this argument.
  • Jean-David Beyer
    Small humidifier.
    I have radiant heat downstairs (slab on grade with 1/2" copper tubing in the slab). I do not need much humidification, but when I do, I used to use a small Honeywell room-size water-boiling electric humidifier. After about 10 years or so, the unit burned out a couple of days ago, so I just ordered a new one (different model).I usually just run it in my bedroom at night.
  • Kevin_in_Denver_2
    Kevin_in_Denver_2 Member Posts: 588
    Higher temp equals lower humidity
    Whenever you raise the temperature of a room, the relative humidity drops. Therefore humidification is just as important in a radiant house as a scorched air house.
    Sinus membranes in the path of the 120F forced air will be dried out worse than in a radiant house. That's why people think the air is drier in a forced air heated house.
    Once that air is mixed with the rest of the air in the room, the relative humidity is the same with both types of heat.
  • Gordy
    Gordy Member Posts: 9,546
    Thats why FA is drier
     A radiant system will never see 120* exchange to the air, like FA does. Most radiant panels be it floor,walls,ceiling will never see temps above 85-95 degrees at the surface. Plus there is less air infiltration than with FA stack effect.
    I have lived in both, and can tell you its not as dry in a radiant home.
    Gordy
