how many btu's max for 5/8 pex tubing
dumberplumber
Member Posts: 1
Need to know how many ft. of baseboard can be installed on 5/8 pex loop
temp?
what water temp a flow rate [or pump]?0 -
What's the flow rate
You can get 6.0 gpm through 5/8" pex. The attachment should help you out.There was an error rendering this rich post.
- 120 Geothermal
