Radiant Heat & The Joist Trak System
Rolf
Member Posts: 1
I'd appreciate any input the group can offer. I'm down to the final issues in signing a new client and he is really intent to using radiant heat and quite certain that we should use a conductive system versus convective. He just asked about a system called Joist Trak and I'm curious if anyone has any experience with the product.
Thanks,
Rolf
Thanks,
Rolf
Many plates installed.
I use 3/8" tubing. I screw in the plates, I know others use a pneumatic staple.
The only way in my opinion to do a joist install is using extruded aluminum.
Good Luck.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 956 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
