oil or electric for domestic hot water
RyanC
RyanC Member Posts: 38
I have a 20 year old Burnham V33 that supplies steam for my heat.  It also supplies hot water through a tankless coil.  In terms of cost to run is this equal to an electic hot water tank?  Would I be better off switching to an electric tank?
Thanks,
Ryan
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,588
    Depends
    on what you pay for oil and electricity. One Kwh is 3400 BTU's.One gallon of oil is 140,000 BTU's. Convert your cost to per BTU and you'll have the answer.Don't forget to multiply the oil number by the eff of the boiler
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,425
    Heres more ideas
    an indirect water heater would allow for your boiler to be cold fire. This means not having to keep the whole boiler to 180 all summer if you do not need the hot water. It also can help if you have volume issues with the old tank-less and supplying fixtures a better flow of water at an even temperature. Instead of scalding hot to tepid.
    cell # 413-841-6726
  • RyanC
    What is an indirect water heater?
    Not to sound dumb but what is an indirect water heater?
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,692
    Indirect
    It's a storage tank for the domestic hot water. It's like a water heater but it has no flue or fire inside of it. Instead, it has a coil through which boiler water circulates. The boiler treats it like a heating zone. Some indirects have tanks within tanks rather than coils. Other's have the boiler water in the tank and the domestic water in the coils. Many ways to get to the same place. When you're not using water they act like a Thermos.
    Retired and loving it.
    Indirects are Great when done well.
    I prefer the ones with coils as the coil is below the water line( on most models) of a steam boiler.
    cell # 413-841-6726
  • RyanC
    Indirect hookup?
    So I would have to pump the boiler water out of the boiler and through the coil in the indirect heater?
    yes
    That is how you do it.
    cell # 413-841-6726
