christmas present to myself....
jpf321
Member Posts: 1,568
lookie at what Santa brought me ..a new glass pipe...
<a href="http://picasaweb.google.com/jpf321/Fitzgibbons400Boiler?authkey=Gv1sRgCNOPnfifvI7MNA#5420442675709015426"><img src="http://lh3.ggpht.com/_JuuICk78iPs/SzlH5RMA9YI/AAAAAAADLfQ/h6NI3OPkOJ0/s128/IMG_9215.JPG" /></a>
<a href="http://picasaweb.google.com/jpf321/Fitzgibbons400Boiler?authkey=Gv1sRgCNOPnfifvI7MNA#5420442855673799346"><img src="http://lh5.ggpht.com/_JuuICk78iPs/SzlIDvm9orI/AAAAAAADLfg/QitL2HkP-e8/s128/IMG_9224.JPG" /></a>
<a href="http://picasaweb.google.com/jpf321/Fitzgibbons400Boiler?authkey=Gv1sRgCNOPnfifvI7MNA#5420443045561737234"><img src="http://lh6.ggpht.com/_JuuICk78iPs/SzlIOy_xoBI/AAAAAAADLfo/9D2ED4t0Jw0/s128/IMG_9216.JPG" /></a>
<a href="http://picasaweb.google.com/jpf321/Fitzgibbons400Boiler?authkey=Gv1sRgCNOPnfifvI7MNA#5420443237162828002"><img src="http://lh3.ggpht.com/_JuuICk78iPs/SzlIZ8xCQOI/AAAAAAADLfw/Fo8bwqHHYOs/s128/IMG_9218.JPG" /></a>
<a href="http://picasaweb.google.com/jpf321/Fitzgibbons400Boiler?authkey=Gv1sRgCNOPnfifvI7MNA#5420443420370978322"><img src="http://lh4.ggpht.com/_JuuICk78iPs/SzlIknRQxhI/AAAAAAADLf8/H6w15KP9T1o/s128/IMG_9220.JPG" /></a>
<a href="http://picasaweb.google.com/jpf321/Fitzgibbons400Boiler?authkey=Gv1sRgCNOPnfifvI7MNA#5420443621030542386"><img src="http://lh5.ggpht.com/_JuuICk78iPs/SzlIwSyOvDI/AAAAAAADLgI/HprjEewMJes/s128/IMG_9221.JPG" /></a>
<a href="http://picasaweb.google.com/jpf321/Fitzgibbons400Boiler?authkey=Gv1sRgCNOPnfifvI7MNA#5420443808347981890"><img src="http://lh6.ggpht.com/_JuuICk78iPs/SzlI7MmMCEI/AAAAAAADLgQ/Ssm-CQNCPX4/s128/IMG_9222.JPG" /></a>
1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics
why?
?gwgillplumbingandheating.com
mainly...
mainly for educational reasons .. so that I can learn about what's going on in my wet return .. i can watch hot water enter (by seeing the convective currents in the pipe) .. i can assess the flow rate... i can see flecks of dirt drop out and settle...it helps learn whether the muddy water in the boiler mug leg is from the boiler or from the rest of the system.
since my system and returns are old, it helps me to understand the state of the pipes.
additionally, i do intend to install magnets .. i figured that if i put a magnet on an iron pipe, i'd magnetize a larger of the pipe than with glass .. i may also permanently magnetize a section of iron... these problems are avoided with glass .. as well, i will be able to see when i have captured a big clump of gunk and will be able to flush it.
lastly, i did want to install the return flush valves and iso gate .. so this gave me an opportunity and motivation to perform those upgrades.1-pipe Homeowner - Queens, NYC
my NEW system pics | my OLD system pics0 -
Why?
Besides it's really cool:-)0 -
Cool!
I get the reason for the magnet, but how are you going to deal with the collected material? Will you have to take it all apart?0 -
Glass Pipe
I can't wait to see the one he installs on the sewer pipe. All kidding aside, I wouldn't put any more money into that boiler. I would save up to replace it. A proper sized boiler for his system would burn 1.05 gal /hr, not 1.75. That .7gals of heating oil per hour of run time. He has installed an hour meter on this boiler just do the math.
Mark0 -
I bought a meat grinder
for myself. I'm going to go make sausage
Laws, sausage, and sludge...
...it's better to not see them being made. Or so they say.0 -
magnet cleanout...
with the flush drain I will perform a normal return flush .. taking the glass out as needed is a 5min job .. the fittings are stainless steel rubber gasketed compression onto bare end pipe .. simply loosen them up and slide it down to the left1-pipe Homeowner - Queens, NYC
completely agreed
since I only took ownership this past summer .. and we had other more pressing "move-in" expenses .. i had to table the boiler replacement this season .. i did have 2 "knuckleheads" through in the early fall to give estimates .. that was all before I found "the wall" .. i'm glad I waited since I am now much more prepared for anyone else that comes through.
i certainly don't like the idea of an oversized and hungry system, but it is what it is right now.
i don't think any of the improvements (or curiosities) will be thrown in the trash when the new boiler arrives...so I don't think of it as wasted money .. money has been spent on vaporstat, low pressure gauge, hour meter, glass pipe, main and rad vents, insulation (although I got the wrong size), Dan's books .. none of which I feel is wasted money...and may even be contributing to $$ savings this year.
i do appreciate the comments, i hope you appreciate my interest in becoming educated and informed in "the art" ... even if some things are deemed as unnecessary or superfluous...if they help me to better understand.. i feel that is valuable.1-pipe Homeowner - Queens, NYC
Replace Boiler
I know all about putting off replacing the boiler. I waited 20 yrs. For most of that time oil was under a $1 a gallon. I switched to gas. I wanted the tank out of my basement. My boiler was truly ancient. It was a Weil-McLain K-167. It had no hartford loop and no lwco. I have no idea what sized nozzle was in it but no doubt it was oversized. I never had any trouble with old boiler andnever paid much attention to it. Just flushed and added water as needed.
Mark0 -
If you make your own
you know how they are made0 -
magnets on return update
in case any of you were being kept up at night waiting for an update on the magnets on my return pipe .. here are some pics from today ..1-pipe Homeowner - Queens, NYC
- 167 Indoor-Air Quality
