Pressuretrol to Vaporstat
Jfonto
Member Posts: 43
I have a 1980's Weil mclain residential steam boiler; is there any reason not to switch to a vaporstat control.
Before we answer that
do you have a one-pipe or a Vapor system? What model W-M is it?All Steamed Up, Inc.
Consulting0 -
vaporstat?
It's a one pipe system and I'd have to dig out the literature but part of the model # was 66. I'll get the whole thing if that's not enough0 -
A Vaporstat is more critical
on a Vapor system, but there's no problem using it on yours. But if the boiler is oversized, a Vaporstat can make it short-cycle as pressure starts to build. If that happens, it may be possible to down-fire the burner slightly- when you look at the boiler model, also tell us what make and model burner is on it- for example, Beckett AFG. Take a picture if you're not sure and post it here.All Steamed Up, Inc.
Consulting0
- 119 Chimneys & Flues
- 116 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
