Pressure/Temperature Interpolation
PCBOILERMAN
Member Posts: 11
How would you answer this question. You have 60 psi at 35 degrees, 72 psi at 45 degrees, what would the pressure be at 41 degrees?
It depends
If they were talking about refrigerant and the refrigerant was r22 then i would give a answer of 70 psi.Knowing that there can be no right answer to the question that was given.
Must be test time again and these are one of those question they know you can not answer correctly.0
