Burner Trips
Sly
Member Posts: 29
Hello,
I have a powerflame dual burner. It trips sporatically. It seems to trip when the burner sits for while after the temp has been set. If the temp is not set, it will cycle on off fine once I hit the reset button. However, once it reaches temp it seems to trip on initial startup again.
Any clues on this?
thanks
sil
Any clues on this?
thanks
sil
burner problems
there may be tech support from powerflame for that burner. some of them will be able to give you an error code to help with diagnostics.--nbc0
- 117 Geothermal
