New room radiant heat
 Adding a room 20x12  in floor radiant being added to a hw baseboard
system  if i branch off boiler outlet at 180 i know i need a mixer to lower
temp but for the room loop do i use valves or loop pumps to
add to existing system(one floor home.) if pumps what size?
                                                Tom1
  • CMadatMe
    CMadatMe Member Posts: 3,086
    You Need
    a  system pump after the mixing vlave for the radiant. What size. Generally a Taco 007 or Grundfos 15-58 but pump sizing is dependent on heat loss, flow rates and head of the system. Without knowing these parameters, your rolling the dice.
  • Russty
    Russty Member Posts: 2
    System Design
    Hi,
    I'm building a 30'x44' two-story addition to my home. The subfloor is already in, and I want to install hardwood on the second floor. I want to heat the second floor via Radient heat tubing added to the bottom of the subfloor.
    1. Where can I go to get a proper system design?
    2. Is it prudent to locate the boiler in the first floor (garage)?
    3. I live in NH, have natural gas, and need to heat my domestic water too. Should I use a boiler, a water heater or an on-demand unit?
    4. Will enough heat transfer through the subfloor and hardwood without having to raise the water temp high enough to cup the hardwood?
    Thanks!
