Modine and Taco
Rob_5
Member Posts: 9
Plan to install a modine hot water unit in garage. Have 3 zones off boiler and adding a forth for modine. Have taco SR503 and picked up a SR501. Not sure of wiring the SR501 with the 503? Picked up a Honeywell L606C for the fan on the modine. Is this a straight forward line in to aquastat and line out to fan? Install on return? Thermostat on wall to Taco? Thank you. Rob
Here's Taco Wiring Guide
The attached wiring guide has what you are looking for.There was an error rendering this rich post.
- 117 Geothermal
