Blue Jean Insulation under radiant? Opinions?
John Ruhnke
Member Posts: 1,020
Has anyone had any experience with blue jean insulation under radiant? Do you find that the water temperatures are higher or lower then fiberglass? I know spray foam is the best but where does blue jean insulation fall? worse or better then fiberglass?
John Ruhnke
John Ruhnke
I am the walking Deadman
Hydronics Designer
Hydronics is the most comfortable and energy efficient HVAC system.
Hydronics Designer
No noticeable difference
I had one job with blue jean insulation, with above sub floor panels and tubing. Rated r-value seems on par with fiberglass.Mice like 'em too.0 -
Dense pack insulation
Blue jean insulation is considered a good candidate for dense pack insulation, and actually has a higher R value per inch than fiberglass insulation.
ME0
- 120 Geothermal
