Zone Valve End Switch current draw
What is the minimum allowable current draw in mA for Honeywell 24 Volt model 8000 and 4000 series motorized zone valves?
  • cid2
    cid2 Member Posts: 4
    zone valve end switch current draw
    The end switch is rated to carry 4.4 amps at 120 vac and 50 va at 24 vac.
    At 24 vac it works out to be a little over 2.0 amps
