Wireless Thermostats
Member Posts: 4,459
again. I've searched the threads for info., but some of the model numbers have been discontinued.
Honeywell:
thermostat: T8665A1002
receiver: W8665E1000
Danfoss:
thermostat: TP-75RF
receiver: RX-3 (3 zones)
Can someone please provide current model numbers and more important, include any feedback and experience you've had with these thermostats, good and bad. I have a customer with a single zone system who wants more control of his system. The return manifold is in the garage next to the boiler and all ½" loops are available for the installation of zone valves.
Honeywell:
Danfoss:
thermostat: TP-75RF
HI YA Alan
I just went throught this search and found that not many companys are producing wireless thermostats. I know Honeywell has them for scorched air but as of yet, not for hydronic.
I actually got a job by competing against a wireless thermostat bid that the owner was concerened about .
Let me know what you find.
Scott0 -
Wireless stats with wired actuators
Check out this link for hydronic systems with manifolds. may be what you are looking for.
http://www.uponor-usa.com/~/media/Files/Technical%20Documents/heating%20resource%20docs/Climate%20Control%20Zoning%20FAQ.aspx?sc_lang=en
Dave H.Dave Holdorf
Taco, Inc
Wow
There you go Dave, thanks...0 -
Honeywell Red Link Wireless
We have been using the new Honeywell wireless technology withe great success. I know of one install where we put a Honeywell FocusPro 5000 in a 4 story all concrete building, with the stat on the fourth floor, and the receiver in the basement, and have not had a problem.
You can check out the complete line of Red Link products at:
http://www.forwardthinking.honeywell.com/products/wireless/wireless_products.html
By the way, the FocusPro and VisionPro (including wireless) stats can be configured for heating only applications including 3-wire zone valves in the installer menu.0 -
Thanks Scott, Dave and Glenn. I'll do some research on those products in the morning.
All the best,
Alan8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 110 Chimneys & Flues
- 979 Plumbing
- 387 Solar
- 17 Recall Announcements
