Riello Pipe Sizes
ChasMan
Member Posts: 462
Does anyone know the return / supply thread sizes on an F3 burner? They give you adapters for 1/4" & 3/8" NPT but I want to know the size of the pipe threads that they are using.
Dang
Well, they are 1/4 BSPP which is disapointing. That means there is no available premade line or fitting and line that will work with a tigerloop without using an adapter. Unless someone can point me to a 1/4 NPT Male to 1/4 BSPP pressure adapter.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 849 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
