Galvanized pipe, why not a good idea?
I've seen it mentioned a few times when someone spots galvanized pipe in a job that it ought to be replaced with regular black steel.  Why is this?
I have an example where the very top venting "antler" setup in my attic was constructed of 3/4 galvanized, and wonder if this is really a big deal to go replace with black steel?
Al
  • Ron Jr._3
    Ron Jr._3 Member Posts: 605
    Not sure
    what you mean by " venting antler setup " , but if it's a closed hot water system , I don't see the harm in having galvanized piping .
  • Al,,,,,
    I cannot see any reason,,,, leave-it be.
  • Al Roethlisberger
    Al Roethlisberger Member Posts: 189
    edited November 2009
    Thanks.
    Yes, it is closed hot-water.
    Al
    hot_rod Member Posts: 27,489
    galvi is a no no
    with glycol, but should be fine on HW.
    Even on a closed loop hydronic I would keep copper and galvi separated by brass or bronze, they seem to not get along well when they butt heads.
    hr.
