Galvanized pipe, why not a good idea?
Al Roethlisberger
Member Posts: 189
I've seen it mentioned a few times when someone spots galvanized pipe in a job that it ought to be replaced with regular black steel. Why is this?
I have an example where the very top venting "antler" setup in my attic was constructed of 3/4 galvanized, and wonder if this is really a big deal to go replace with black steel?
Al
Al
Not sure
what you mean by " venting antler setup " , but if it's a closed hot water system , I don't see the harm in having galvanized piping .0 -
Al,,,,,
I cannot see any reason,,,, leave-it be.0 -
Thanks.
Yes, it is closed hot-water.
Thanks
AlThere was an error rendering this rich post.
galvi is a no no
with glycol, but should be fine on HW.
Even on a closed loop hydronic I would keep copper and galvi separated by brass or bronze, they seem to not get along well when they butt heads.
hr.Bob "hot rod" Rohr
Living the hydronic dream0
- 120 Geothermal
