DPDT RELAY
I was wondering if anyone has a part number suggestion for a 24v ac coil DPDT relay.
I will be using it to switch between 2 different thermostat's.
Thank You
Tim
Winter Park, CO & Arvada, CO
    Steamhead Member Posts: 18,451
    Any standard general-purpose relay
    should work. Honeywell's is the R8222D1014. If you need to also install a transformer, the R8285B1053 fan center combines a DPDT relay with a 40VA transformer, and fits neatly on a 4x4 box.
    Consulting
  • Jay_14
    Jay_14 Member Posts: 39
    relay
    tekmar Relay 003 - DPDT relay with 24 Vac coil, 10A contacts
  • Tim Potter
    Tim Potter Member Posts: 274
    Thank You
    Thanks for the reply - good info
    Tim
