Rust in five year old boiler
bruce_21
Member Posts: 246
in Oil Heating
I went to check out a no heat call and found all this rust in the chamber. What is doing this? I've seen plenty of boilers that won't go from soot, but this is the cast iron rusting away and the unit is only five years old.
could be a few things
Nasty oil fron an old tank, really back combustion air ( are there appliances not venting in the same room?) Plain damp nasty air in the basement. Maybe a leak in the sections? Has the unit been serviced for the past 5 years? Really low return temps causing condensing in the boiler? Bypass or primary secondary piping may be called for.Cost is what you spend , value is what you get.
cell # 413-841-6726
more details on rusty boiler
Its a steam boiler, return piping is short but not insulated. There is an outside combustion air kit on it. There is a washer and dryer which vents to the outside about 15 feet away and a gas water heater venting into the same chimney (which is in the center of the house).0 -
Rusting boiler
From your photo, I see the bottom valve of a sight glass, so I assume it's a steamer. Check this boiler out very carefully. The color can indicate overheating or a leak above the water line. Fill it up and look for a leak. Are the vents OK? Is the boiler adding a lot of water? ( a plug here for the HydroLevel VXT-120....it will tell you how much water is being added.
Could be from the oil but looks like a possible leaker......check it out thoroughly.0 -
I agree with Al
I'd assume it might be an internal water leak .0 -
"O" Rings
Looks like another Weil Mclain, I have 9 out of 11 that seep when they get cold. And do they have the excuses as to why it leaks.0
- 87K THE MAIN WALL
- 58 Biomass
- 112 Chimneys & Flues
- 106 Geothermal
- 980 Plumbing
- 388 Solar
