DPDT RELAY
Tim Potter
Member Posts: 274
I was wondering if anyone has a part number suggestion for a 24v ac coil DPDT relay.
I will be using it to switch between 2 different thermostat's.
Thank You
Tim
Thank You
Tim
Winter Park, CO & Arvada, CO
Any standard general-purpose relay
should work. Honeywell's is the R8222D1014. If you need to also install a transformer, the R8285B1053 fan center combines a DPDT relay with a 40VA transformer, and fits neatly on a 4x4 box.All Steamed Up, Inc.
Consulting0 -
relay
tekmar Relay 003 - DPDT relay with 24 Vac coil, 10A contacts0 -
Thank You
Thanks for the reply - good info
TimWinter Park, CO & Arvada, CO0
- 50 Industry Classes
