How many Taco products can you fit in one job?
Steven Gronski
Member Posts: 98
Just started a job at my friends house this week, thought I would share some quick pictures on whats been accomplished so far.............I guess the question of the day is what isnt Taco in the first Picture? Lets see I have the following:<ul><li>a 3 speed pump</li><li>a OOR single speed radiant pump</li><li>a I-series 3 way mixing valve </li><li>a 4900 series air removal</li><li>a 008 variable speed delta pump</li><li>a 007 IFC pump</li><li>a Taco 1” Hydraulic separator</li><li> Taco freedom flanges in ¾” and 1”</li><li>¾” ESP zone valves</li><li>(soon to be added SR 501 and 503 for the end switching requirements by Viessmann for the Vitoden 100 to allow for priority hot water)</li><li>
Damn, did I miss anything? I bet you didn’t think that you could fit that many Taco products on one job, and the costs are not that bad either.
Steven Gronski
Gronski Plumbing and Heating Inc.
Cranston RI</li></ul>
Steven Gronski
Where's the...
Taco Series 866 Fractional Gonkulator? It'll never work without one! ;-)
Pretty otherwise...0 -
fast fill valve
fast fill valve.0 -
And
Don't forget the model 243 Frisbee Inducifier. Can't believe this system will work without one.0
