Thermostat for Viessmann
jim_51
jim_51 Member Posts: 69
Hello
I have a Viessmann Vitogas 100 with a outdoor reset and vitrotronic 200 control. I am looking to replace my thermostat with a setback. Currently have two zones but will only be replacing main one at this time. Any suggestions on what type or model thermostat I should purchase? Thanks for your help.
  • Paul Pollets
    Paul Pollets Member Posts: 3,671
    Viessmann Controls
    There are 2 "thermostats" compatible with the Vitotronic control, the Vitotrol 200 or 300. The 300 has setback capabilities and can remotely change all zones (heating circuit 1 or 2) and the DHWT. They are considered "remote controls"
  • jim_51
    Thanks If I did not want to use the vitotrol units what other thermostats would you recommend.
  • CMadatMe
    CMadatMe Member Posts: 3,086
    I Think
    Paul gave you the anwser. You have to use the Vitotrols.
