Grundfos Alpha and Taco Delta-t circulators
bob eck
Member Posts: 930
Hello professional heating contractors.
Just checking with you if anyone is using the Grundfos Alpha circulator pump or the Taco Delta-t circulator pump.
What was the reason you used one circulator over the other?
Are they working well for you? Did you have any trouble with either of them?
Thanks for the info.
Site search
do a site search and you'll get lots of comments0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
