Fire Hazard?
dennis8
Member Posts: 15
Just insulated my steam pipes. I insulated the first riser that comes out of the boiler. The insulation is about 4 inched from the top of the boiler. I know that the fiberglass is fireproof but what about the foil backed paper? I looked at diagrams of my boiler and it appears that the open flame is on the very bottom and then there is a large cast iron block that the riser comes out of. I am thinking that I am in the clear as far as a fire hazard. Any thought would be appreciated.
Thanks in advance.
Dennis
Thanks in advance.
Dennis
You should be fine
there's plenty of separation between the flame and the insulation.All Steamed Up, Inc.
Consulting0 -
Thanks
Hi Steamhead,
Thanks for the feedback. Much appreciated!!
Dennis0
