thermostat wiring
STEAM DOCTOR
Member Posts: 2,000
i just replace an OLD thermostat with a Honeywell programmable. the old wires were black so i could not trace them to the basement to see were they went. this is a two wire system (just one hot water boiler on the thermo). i called my supplier who said that as long as one is connected to Rh and one is connected to w then it doesn't matter which wire is which. i just wanted to make sure that that is accurate. thanks
T-stat
Should be okay. 2 wires T-stat is just a switch that opens and closes on temperature.
Jim0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
