Boiling out or cleaning a new boiler
russiand
Member Posts: 75
in Oil Heating
Reading new boiler instructions, it says that a new boiler needs to be cleaned of oil, debris, etc by boiling out. This seems to apply to both steel and cast iron. What is the best or most common way of accomplishing this.
Thanks
Thanks
What type ?
Is the boiler steam or hot water ?0 -
Hot water
Hotwater either cast iron or steel0 -
Rhomar Water
You might want to take a lookon Rhomar Water's website. They are good people to work with.
http://www.rhomarwater.com/products/residential-hydronic-radiant/0
- 167 Indoor-Air Quality
