air venting recommendations
STEAM DOCTOR
STEAM DOCTOR Member Posts: 2,412
thanks for the great site. where can i find info on recommendations for main air venting and radiator air venting. also where can i find info on venting capacity of various vents so that i can compare. thanks.
    Steamhead Member Posts: 17,894
    Start with your main vents
    measure the length and diameter of each steam main and we can tell you what you need.
    Consulting
  • STEAM DOCTOR
    will do
    will do(might take a few days). thanks
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,577
    venting info
    there is an e-book available from the shop here listing the capacities of all the various vents. my view is: you can never be over-vented on the main lines, as long as they are more or less equal [if more than one line].
    therefore the gorton #2 is my choice, and if your mains are big, maybe several!
    concentrate on improving  the main vents  first, as they do all the work, and get all the abuse. most likely your rad vents are ok. if they are not, then you will see that after your replacement of the mains.--nbc
  • Venting Book
    Hi- I gave another person the info on getting the Vent Book.
    Use this link to get there
    - Rod
    http://www.heatinghelp.com/forum-thread/127696/Balancing-A-steam-system
