Buderus GB 142 gray particulate in condensate trap
Keith_23
Keith_23 Member Posts: 17
I have a GB 142 that went in as a replacement boiler 3 years ago.  It uses the old galvanized pipes to heat baseboard radiators only.  The copper boiler pipes interface the galvanized branch lines via dielectric unions.  It uses unconditioned city water.  I did not clean the heat exchanger or the condensate trap last heating season but I did the summer before.
   I opened it up after a summer of it being off and noticed a small pile of whiteish gray particulate in the condensate trap.  Is this something to worry about?
TIA
Keith
  • Keith_23
    Can anyone help?
    Can anyone answer this? Should I worry?
    Keith
  • mjcromp
    mjcromp Member Posts: 57
    This is normal
    Nothing to be concerned about. The stuff you clean off the heat exchanger. It's just found it's way down into the trap.
