wood and electric
stressed
Member Posts: 1
I'm trying to install a outside wood boiler to my current electric system was wondering if anyone could point me in the easiest way to plum this. I currently have a electric boiler that heats my in floor heat in the basement that is a pressurized system around 13 pounds, and a electric coil with forced air for my upstairs, plan to use a plenum off my wood in the ducting to heat the up stairs and a heat exchanger to heat my in floor in the basement. Any thoughts to this
Wood Boilers
They are really into wood boilers and the piping of them here: http://www.hearth.com/econtent/index.php/forums/viewforum/21/
Good Luck0 -
Wood and Water
The Mix. This article, by John Siegenthaler explains the basic piping and control concepts.
It is a good article to start with. It is two parts the second in the next months issue.
www.hpacmag.sartech.ca/archives/2009/3_April.pdfBob "hot rod" Rohr
Living the hydronic dream0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
